[Qgis-developer] OTB Configuration for Processing Toolbox
bjorn.burr.nyberg at gmail.com
Fri Oct 4 11:49:24 PDT 2013
Cheers,
That was simple enough... however i've run into another problem which i hope
is just as simple. Whenever i run an application with a vector output i
receive the following error (this example from Mean Edision Segmentation).
Segmentation -filter edison -in
Users\INSTAL~1.000\AppData\Local\Temp\processing\73bc3696f1044433be48fa47d40f293b\-out.tif
-filter.edison.spatialr 5 -filter.edison.ranger 15 -filter.edison.minsize
100 -filter.edison.scale 1 -mode.vector.stitch true -mode.vector.minsize 1
-mode.vector.simplify 0 -mode.vector.layername layer -mode.vector.tilesize
1024 -mode.vector.startlabel 1 -mode.vector.outmode ulco -mode vector
-mode.vector.out
C:\Users\INSTAL~1.000\AppData\Local\Temp\processing\601c72ba4790494694bbc4e28c6288ab\-mode
vector -mode.vector.out.shp
ERROR: option -mode.vector.out.shp does not exist in the application.
This is the Segmentation application.
(here it starts to describe the parameters for that application)
Any ideas?
Thanks
Bjorn
View this message in context: http://osgeo-org.1560.x6.nabble.com/OTB-Configuration-for-Processing-Toolbox-tp5081774p5081903.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
