[Qgis-developer] Python: Union selected polygons in a layer
Andreas Neumann
a.neumann at carto.net
Sat Oct 5 13:58:43 PDT 2013
Hi Daniel,
Thanks - this should do the trick! And it explains why I did not find
"Union".
Will try on Monday when I am back in the office.
Andreas
Am 05.10.2013 11:55, schrieb Daniel:
> Try the QgsGeometry::combine() method.
> http://www.qgis.org/api/classQgsGeometry.html#a63244d3435cc99794b82a6cbd0af0eb5
> Quoting class doc
> *Note:*this operation is not called union since its a reserved word in C++.
> On Sat, Oct 5, 2013 at 8:07 AM, gene <martin.laloux at gmail.com> wrote:
>> I also do not see union in Geometry Handling
>> <http://www.qgis.org/en/docs/pyqgis_developer_cookbook/geometry.html> :
>> the layer:
>> for elem in layer.getFeatures():
>> geom= elem.geometry()
>> print geom.exportToGeoJSON()
>> { "type": "LineString", "coordinates": [ [203271.93800293002277613,
>> 89444.43836556003952865], [204056.96179387057782151,
>> 89149.26942016639804933], [204590.77797171016572975,
>> 89111.58827820124861319], [204823.14501382855814882,
>> 89456.99874621508934069] ] }
>> { "type": "LineString", "coordinates": [ [204541.79248715547146276,
>> 89757.64295613372814842], [204474.17871974196168594,
>> 90086.05268357080058195] ] }
>> Using the see <https://github.com/inky/see> module (alternative to
>> Python's dir()):
>> from see import see
>> see(geom)
>> hash() help() repr()
>> str()
>> .Error() .addPart() .addRing()
>> .adjacentVertices() .area() .asGeometryCollection()
>> .asMultiPoint() .asMultiPolygon() .asMultiPolyline()
>> .asPoint() .asPolygon() .asPolyline()
>> .asWkb() .avoidIntersections() .boundingBox()
>> .buffer() .centroid()
>> .closestSegmentWithContext()
>> .closestVertex() .closestVertexWithContext()
>> .combine() .contains() .convertToMultiType()
>> .convexHull() .crosses() .deletePart()
>> .deleteRing() .deleteVertex() .difference()
>> .disjoint() .distance() .equals()
>> .exportToGeoJSON() .exportToWkt() .fromMultiPoint()
>> .fromMultiPolygon() .fromMultiPolyline() .fromPoint()
>> .fromPolygon() .fromPolyline() .fromRect()
>> .fromWkb() .fromWkt() .insertVertex()
>> .interpolate() .intersection() .intersects()
>> .isGeosEmpty() .isGeosEqual() .isGeosValid()
>> .isMultipart() .length() .makeDifference()
>> .moveVertex() .overlaps() .reshapeGeometry()
>> .simplify() .splitGeometry() .sqrDistToVertexAt()
>> .symDifference() .touches() .transform()
>> .translate() .type() .validateGeometry()
>> .vertexAt() .within() .wkbSize()
>> .wkbType()
>> I see .intersection(), .touches() but no .union()
>> Whereas with Shapely:
>> from shapely.geometry import LineString, shape
>> from json import loads
>> # empty shapely geometry
>> myunion = LineString()
>> geom = elem.geometry()
>> # transformation of the QGIS geometry to shapely geometry with
>> the geo_interface
>> geoms = shape(jloads(elem.geometry().exportToGeoJSON()))
>> myunion = myunion.union(geoms)
>> print myunion
>> MULTILINESTRING ((203271.9380029300227761 89444.4383655600395286,
>> 204056.9617938705778215 89149.2694201663980493, 204590.7779717101657297
>> 89111.5882782012486132, 204823.1450138285581488 89456.9987462150893407),
>> (204541.7924871554714628 89757.6429561337281484, 204474.1787197419616859
>> 90086.0526835708005819))
>> and
>> gem = QgsGeometry.fromWkt(myunion.wkt)
>> gem
>> <qgis.core.QgsGeometry object at 0x12986fef0>
>> print gem.exportToGeoJSON()
>> { "type": "MultiLineString", "coordinates": [ [
>> [203271.93800293002277613, 89444.43836556003952865],
>> [204056.96179387057782151, 89149.26942016639804933],
>> [204590.77797171016572975, 89111.58827820124861319],
>> [204823.14501382855814882, 89456.99874621508934069] ], [
>> [204541.79248715547146276, 89757.64295613372814842],
>> [204474.17871974196168594, 90086.05268357080058195] ] ] }
>> or with ogr (same result):
>> from osgeo import ogr
>> # empty ogr geometry
>> myunion = ogr.Geometry(ogr.wkbLineString)
>> # transformation of the QGIS geometry to ogr geometry
>> geoms = ogr.CreateGeometryFromWkb(geom.asWkb())
>> myunion = myunion.Union(geoms)
>> Is there a comparable solution with PyQGIS ?
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/Python-Union-selected-polygons-in-a-layer-tp5081862p5081959.html
>> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
