[Qgis-developer] Tr : New QGis project, application : version is empty and wms layer invalid
chrome2006-dev at yahoo.com
Sun Oct 6 14:47:31 PDT 2013
Hi Daniel
Thanks for your help.
I tried nasa server within my app without success, rlayer is still invalid.
I also tried within the QGis app, the server returned "this server no longer
provide full WMS services!"...
I also notice that my app starts immediatly, I'm not sure wether it should take
some seconds or not....
Anyway, I added some paths in my app (defaultsvg and plugins), and now my wms server is "Valid'.
But there's still nothing displayed in my map. Here's the current code regardings layers :
QgsMapLayerRegistry::instance()->addMapLayer(rlayer);
QList <QgsMapCanvasLayer> myLayerSet;
myLayerSet.append(QgsMapCanvasLayer(rlayer, TRUE));
mapCanvas->setLayerSet(myLayerSet);
mapCanvas->zoomScale(1/10000);
mapCanvas->centerOn(5.7, 45.2);
mapCanvas->update();
mapCanvas->refresh();
De : Daniel <danielvaz at gmail.com>
À : "chrome2006-dev at yahoo.com" <chrome2006-dev at yahoo.com>
Cc : "qgis-developer at lists.osgeo.org" <qgis-developer at lists.osgeo.org>
Envoyé le : Dimanche 6 octobre 2013 21h06
Objet : Re: [Qgis-developer] New QGis project, application : version is empty and wms layer invalid
I don't know if you should receive "2.0" as output of applicationVersion() method.
It's because setApplicationVersion() and setApplicationName() are called from src/core/main.cpp (QGIS code).
The class QgsApplication don't call setter methods, so I don't know what are the supposed behavior when I call these methods.
It works for me
QString uri= "url=http://wms.jpl.nasa.gov/wms.cgi&crs=EPSG:4326&format=image/jpeg&layers=global_mosaic&styles=pseudo";
qDebug() << "uri" << uri;
QgsRasterLayer *rlayer = new QgsRasterLayer(uri, "layer_name", "wms", false);
qDebug() << rlayer->isValid();
Hope it helps you
On Sun, Oct 6, 2013 at 2:32 PM, chrome2006-dev at yahoo.com <chrome2006-dev at yahoo.com> wrote:
>Hi
>This is my first attemp with QGIS. I'm using 2.0 version.
>My first goal is a proof of concept with a wms map and a vector map.
>I started with the wms service. You'll find the code below, there are two
>things that don't go well.
>First, QgsApplication::applicationVersion() is "", Did I do something wrong in
>initialization ?
>Second, my wms layer is not valid but maybe it is only because of the first question...
>main.cpp
>int main(int argc, char *argv[])
> QgsApplication app(argc, argv, TRUE);
> MainWindow w;
> w.show();
> return app.exec();
>mainwindow.cpp
>MainWindow::MainWindow(QWidget *parent) :
> QMainWindow(parent),
> ui(new Ui::MainWindow)
> ui->setupUi(this);
> QgsApplication::setPrefixPath("/usr/lib/qgis", false);
> QgsApplication::initQgis();
> qDebug()<<
QgsApplication::applicationVersion(); // <<------------------- return empty string
> mapCanvas = new QgsMapCanvas(this);
> mapCanvas->enableAntiAliasing(true);
> mapCanvas->useImageToRender(false);
> mapCanvas->setCanvasColor(QColor(255, 255, 255));
> mapCanvas->freeze(false);
> mapCanvas->setVisible(true);
> mapCanvas->show();
> QVBoxLayout* lyt = new QVBoxLayout(ui->centralWidget);
> lyt->addWidget(mapCanvas);
> QString uri = "crs=EPSG:4326&featureCount=10&format=image/gif&layers=osm_auto:all&styles=&url=http://129.206.228.72/cached/osm";
> QgsRasterLayer* rlayer = new QgsRasterLayer(uri, "test",
"wms", true);
> if (!rlayer->isValid()) qDebug() <<"invalid wms"; // <<--------------------- It is invalid !
> mapCanvas->layers().append(rlayer);
>Regards
>Juliette
>_______________________________________________
>Qgis-developer mailing list
>Qgis-developer at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/qgis-developer
Daniel Vaz
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131006/bb6fc766/attachment-0001.html>
