[Qgis-developer] Possible bug in Processing>GRASS
Paolo Cavallini
cavallini at faunalia.it
Wed Oct 9 10:35:18 PDT 2013
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi all.
When running a GRASS command through Processing, the import creates a
"cat" column. If the same layer is used as input for another GRASS
commend, the cat column is renamed as cat_, and a new cat column is
created. If this second layer is used once more as input, the renaming
of cat in cat_ fails, because the column already exists. Following
analyses may fail.
Did I interpret it correctly? Should I open a ticket?
All the best.
Paolo Cavallini - Faunalia
www.faunalia.eu
Full contact details at www.faunalia.eu/pc
Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.14 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAlJVk9YACgkQ/NedwLUzIr658wCeO4+RSsZBbRsSjtFSA/Vy1CwE
FBIAn3JlvROlUXBCu/2BHYVynxEQlXMF
=k6Yv
-----END PGP SIGNATURE-----
