[Qgis-developer] test new android package
    Marco Bernasocchi
    marco at bernawebdesign.ch
    Thu Oct 10 09:55:38 PDT 2013
Hi all, I've been working on creating an android packae that is smaller
than 50mb to fit the playstore.
the pakage now includes only a small subset of the needed libs, all
other libs are downloaded on the first run by ministro.
all in all you will be downloding about 30mb for the apk plus 200mb
dependencies plus 40mb qt, so do it on a wifi, i know it got bigger
(used to be 150mb apk), but the adventage is that now qgis is small
enough for the market (thus update notification will be available) and
for each update you will have to rownload only what actually changed.
To achieve this, I created a reporitory at
http://android.qgis.org/repository/ that can actually be used by any
android qt app that needs any of the available libs.
so please, help me test this package and just report if the installation
worked and you could start QGIS.
thanks a lot Marco
https://db.tt/sBa0e2Pu
Marco Bernasocchi
http://opengis.ch
