[Qgis-developer] Reliable way to determine a groupIndex in the legend tree
Duarte Carreira
DCarreira at edia.pt
Fri Oct 11 02:13:03 PDT 2013
The group checkbox, imho, should *not always* switch children on/off. You should have a modifier to get this as a secondary behavior, like pressing the ctrl key when (un)checking the group checkbox. The primary behavior of the group switch should be to make the children invisible or visible, regardless of the children's visibility being on or off.
In the primary behavior when the parent is turned OFF, the children are not drawn but retain their checked or uncheck status.
If you use the secondary behavior then unchecking the parent will uncheck the children. Same would apply when checking the parent on.
Duarte
De: aperi2007 [mailto:aperi2007 at gmail.com]
Enviada: quinta-feira, 10 de Outubro de 2013 12:59
Para: qgis-developer at lists.osgeo.org
Assunto: Re: [Qgis-developer] Reliable way to determine a groupIndex in the legend tree
I guess instead that much better should be a group checkbox that enable/disable the under childs layer.
This allow OFF the actual configuration or ON that same configuration.
Actually the group checkbox when checked put ON all the layer.
This often is mean too much information .
Instead the mutual exclusive need to choose only one.
And in that case disable and ri-enable will reput the same original clayer.
Andrea.
On 10/10/2013 10:08, Vincent Schut wrote:
On 10/09/2013 11:41 PM, Nyall Dawson wrote:
Personally, I am also interested in enhancing group options in the layer
tree. Groups are not just stupid containers with only toggling of
visibility. They could also have a group opacity and blending and group
metadata. Later on we may also have clipping and masking on groups. So
we really should have an extensible mechanism for groups as new group
features appear.
One thing I'd love to see is the ability to make the layers in a group "mutually exclusive". (ie, imagine radio buttons instead of checkboxes for controlling the visibility of layers within that group). I find I'm often going through a process of switching one layer on, then switching a bunch of other layers off for comparison purposes. A mutually exclusive layer group which automatically switched the other child layers off when I select a layer would make this process much nicer!
+1 for this feature from a frequent user!
Best,
Vincent.
Nyall
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org<mailto:Qgis-developer at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131011/bb58057b/attachment-0001.html>
