[Qgis-developer] Print Composer - map frame centered to layer/object/map center
Benoît Laurent blaurent at heurisis.eu
Fri Oct 11 02:37:25 PDT 2013
Hello,
I encounter the same problem as previously described :
http://lists.osgeo.org/pipermail//qgis-user/2013-January/020842.html
Is there a solution ?
Regards,
Benoît
