[Qgis-developer] Reliable way to determine a groupIndex in the legend tree
Sandro Santilli
strk at keybit.net
Fri Oct 11 04:55:03 PDT 2013
On Fri, Oct 11, 2013 at 01:35:44PM +0200, Vincent Schut wrote:
> On 10/11/13 11:48, Sandro Santilli wrote:
> >On Fri, Oct 11, 2013 at 09:33:05AM +0000, Andreas Neumann wrote:
> >>Am 11.10.2013 09:22, schrieb Sandro Santilli:
> >>But there is still use-case for the radio-button like behaviour. Imagine
> >>having a group with a series of orthoimages of different years and you
> >>quickly want to see each year. In this case, the radio-button behaviour
> >>would save you one click. So I don't think that this contradicts the
> >>other proposal listed above here.
> >Maybe this could be obtained with secondary behavior (SHIFT-click) on layers,
> >but it sounds like something that easily becomes confusing (conflicting
> >with radio-on-groups, undefined behavior for unchecking etc.).
> switching between several raster layers is exactly the main (only)
> use I have for this, and as we are mainly doing remote sensing stuff
> here, including lots of time series, it is something I really
> frequently miss. (Practical example: you have several Landsat
> rasters from different times for the same area, all of them have
> clouds but not in the same place. By switching between layers, you
> can easily get a 'cloudfree' view of the entire area.)
> IMHO 'undefined behavior for unchecking' should not be a problem;
> usually unchecking simply is disabled for radio groups. I do not
> know any UI with radio groups where you can uncheck a selected item
> by clicking it again... I think having it as a secondary behaviour
> is just confusing. I'd rather see groups have a 'selection type'
> property, which defines the selection behaviour within that group
> (and on that level only). Could you explain what you mean with
> 'conflicting with radio-on-groups' (what are 'radio-on-groups')?
By 'radio-on-groups' I meant using radio behavior on groups rather
than on layers. Having "selection type" as a parameter of a group
solves the complexity problem I had in mind.
--strk;
