[Qgis-developer] Installing qgis 2.0.1
Paolo Cavallini cavallini at faunalia.it
Mon Oct 14 09:00:07 PDT 2013
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Il 14/10/2013 17:54, Paolo Cavallini ha scritto:
>> I understood that an osgeo standalone package for 2.0.1-3 was underway: am I wrong?
>> In case not, when could we expect it?
>> Also, in Debian unstable, installation fails because it requires a grass642 package,
>> which is not available.
>> Any hint on how to solve this?
> also, globe plugin seems to have similar issues on Debian.
BTW, installing it anyway results in:
QGIS died on signal 11
warning: Could not load shared library symbols for linux-vdso.so.1.
Do you need "set solib-search-path" or "set sysroot"?
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
warning: no loadable sections found in added symbol-file system-supplied DSO at
0x7fffae5fe000
0x00007f238d2ce0aa in __libc_waitpid (pid=6688, stat_loc=0x7fffae520cbc, options=0)
at ../sysdeps/unix/sysv/linux/waitpid.c:31
31	../sysdeps/unix/sysv/linux/waitpid.c: File o directory non esistente.
[Current thread is 1 (Thread 0x7f239493c780 (LWP 6687))]
#0  0x00007f238d2ce0aa in __libc_waitpid (pid=6688, stat_loc=0x7fffae520cbc,
options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:31
        resultvar = 18446744073709551104
        oldtype = <optimized out>
        result = <optimized out>
#1  0x00000000004ec457 in qgisCrash(int) ()
No symbol table info available.
#2  <signal handler called>
No locals.
#3  0x00007f239033cd0c in QMetaObject::indexOfSignal(char const*) const () from
/usr/lib/x86_64-linux-gnu/libQtCore.so.4
#4  0x00007f236cccb3bd in ?? () from /usr/lib/python2.7/dist-packages/PyQt4/QtCore.so
#5  0x00007f236cfbbfa3 in ?? () from /usr/lib/python2.7/dist-packages/sip.so
#6  0x00007f236cfbcaec in sip_api_connect_rx () from
#7  0x00007f236cc95303 in ?? () from /usr/lib/python2.7/dist-packages/PyQt4/QtCore.so
#8  0x00007f236d308aa4 in PyEval_EvalFrameEx () from
/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0
#9  0x00007f236d30ab1d in PyEval_EvalCodeEx () from
#10 0x00007f236d30acb0 in ?? () from /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0
#11 0x00007f236d2f6453 in PyObject_Call () from
#12 0x00007f236d276a5d in ?? () from /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0
#13 0x00007f236d2f6453 in PyObject_Call () from
#14 0x00007f236d2fb8ef in ?? () from /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0
#15 0x00007f236d2f82cf in ?? () from /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0
#16 0x00007f236d2f6453 in PyObject_Call () from
#17 0x00007f236d3061e6 in PyEval_EvalFrameEx () from
#18 0x00007f236d30ab1d in PyEval_EvalCodeEx () from
#19 0x00007f236d30acb0 in ?? () from /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0
#20 0x00007f236d2f6453 in PyObject_Call () from
#21 0x00007f236d276a5d in ?? () from /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0
#22 0x00007f236d2f6453 in PyObject_Call () from
#23 0x00007f236d2d4d97 in PyEval_CallObjectWithKeywords () from
#24 0x00007f236d21c7f8 in PyInstance_New () from
#25 0x00007f236d2f6453 in PyObject_Call () from
#26 0x00007f236d3061e6 in PyEval_EvalFrameEx () from
#27 0x00007f236d308a29 in PyEval_EvalFrameEx () from
#28 0x00007f236d308a29 in PyEval_EvalFrameEx () from
#29 0x00007f236d30ab1d in PyEval_EvalCodeEx () from
#30 0x00007f236d30ae02 in PyEval_EvalCode () from
#31 0x00007f236d2375a9 in PyRun_StringFlags () from
#32 0x00007f236d733dd8 in QgsPythonUtilsImpl::evalString(QString const&, QString&) ()
from /usr/lib/libqgispython.so.2.0.1
#33 0x00007f236d731051 in QgsPythonUtilsImpl::startPlugin(QString) () from
#34 0x000000000067947a in QgsPluginRegistry::loadPythonPlugin(QString) ()
#35 0x000000000067bf0e in QgsPluginRegistry::restoreSessionPlugins(QString) ()
#36 0x0000000000527672 in QgisApp::QgisApp(QSplashScreen*, bool, QWidget*,
QFlags<Qt::WindowType>) ()
#37 0x00000000004e7440 in main ()
gdb returned 0
Paolo Cavallini - Faunalia
www.faunalia.eu
Full contact details at www.faunalia.eu/pc
Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.15 (GNU/Linux)
Comment: Using GnuPG with Icedove - http://www.enigmail.net/
iEYEARECAAYFAlJcFQcACgkQ/NedwLUzIr6loACghQRFOqGVFerX4g0s/eG6NCQ2
0JIAn1OnHxtrkrMbTCz+ps+GYnLCCBRl
=kDIO
-----END PGP SIGNATURE-----
