[Qgis-developer] paletted rasters with class labels
Vincent Schut schut at sarvision.nl
Wed Oct 16 06:12:11 PDT 2013
Since version 2 qgis does not seem to support paletted rasters (e.g.
tiff's with colortable) with a label for each raster class, is that
correct? In version 1.8, in the colormap tab of the raster properties,
the palette of the raster (if any) would automatically be used, and you
could add (or qgis would load, if they were available in the raster
metadata) a label/name for each of the colors/classes. In the new
version, a raster is either of type 'palette' but that has no option to
use/add labels (but does use the internal palette of the raster), or it
is rendered as 'singleband pseudocolor', which has labels per class, but
cannot use the raster internal colortable.
We really miss this feature now.
Should I file a new enhancement request/bug?
Best regards,
Vincent.
PS over the whole, version 2.0 is a great improvement, kudo's to all the
devs! :-)
