[Qgis-developer] Select all elements in the view ...
Matthias Kuhn matthias.kuhn at gmx.ch
Wed Oct 16 23:08:04 PDT 2013
Hello Roberto,
If you open the attribute table, and apply a filter (e.g. "Show elements
visible on the map") and then press Ctrl+a (click on the table first if,
so it will get the keystrokes) or right click => "select all"  the
features which match the current filter (= are visible on the table)
will become selected.
This works only on one layer, so for multiple layers you will have to do
this repeatedly.
Regards,
Matthias
On 16.10.2013 12:56, Geo DrinX wrote:
> Hello,
> somebody knows if it just exists a plugin that select all elements (of
> one or more layers) contained in the QGis view ?
> I need something similar to the "Show elements visible in the map"
> button of the Attributes table, but selecting the elements.
> Thank you for any info about this
> Roberto
> Qgis-developer mailing list
