[Qgis-developer] Poligon coordinates in PyQgis 2
Geo DrinX
geodrinx at gmail.com
Fri Oct 18 00:13:19 PDT 2013
> in the same way as before but with layer.getFeatures():
> layer = qgis.utils.iface.activeLayer()
> for elem in layer.getFeatures():
> geom= elem.geometry()
> poly = geom.asPolygon()
> poly.wkbType() == QGis.WKBPolygon
> True
> # coordinates of vertex:
> print poly
> [[(232139,110988), (232673,110410), (232311,110090),
> (231814,110190),
> (231684,110648), (232139,110988)]].
...strange, because also using your code, I had this error
AttributeError: 'list' object has no attribute 'wkbType'
What I do not understand is: for what reason getting coordinates is
different from Lines and Polygon ?
Perhaps, Is this a new of PyQGis 2 ?
Thank you
Roberto
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131018/b009008a/attachment.html>
