[Qgis-developer] Teaching Processing: notes from the wild
Paolo Cavallini
cavallini at faunalia.it
Fri Oct 18 08:01:19 PDT 2013
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi all.
Just finished a course on GIS analyses, following mainly the sextante tutorial; here
my notes:
* Random selection: the selection does not appear, as the module is not refreshing
the view
* Split randomly: the % is not exact (e.g. if I select a 20/80 split, I get 22/78 etc.)
* Create graticule from extent: with lines, one of the points (first North-West) is
left out; with polygons it is ok
* In the Log viewer, the button Cancel is misleading, and can lead to loss of
important data a bit too easily; better to give a warning before actually deleting
* the Field calculator is barely usable without a dropdown list of fields and
functions; on win it does not seem to work (most or all calculations end up with all
NULLs); unclear if this is due to minor edit issues from users (quite likely without
the dropdowns)
* it seems impossible to make conditional models (if this value is ... then run this
command, else this other one): am I correct? this would be a major improvement IMHO
* I cannot have OTB running, neither on Debian nor on Win (osgeo4w 32 bit)
* I get a systematic crash when attempting to edit Processing or R scripts, but this
may be a local issue
warning: no loadable sections found in added symbol-file system-supplied DSO at
0x7ffff49fe000
0x00007fcb55dc50f7 in __libc_waitpid (pid=<optimized out>, stat_loc=<optimized out>,
options=<optimized out>) at ../sysdeps/unix/sysv/linux/waitpid.c:40
40 ../sysdeps/unix/sysv/linux/waitpid.c: File o directory non esistente.
[Current thread is 1 (Thread 0x7fcb5d433780 (LWP 14528))]
#0 0x00007fcb55dc50f7 in __libc_waitpid (pid=<optimized out>, stat_loc=<optimized
out>, options=<optimized out>) at ../sysdeps/unix/sysv/linux/waitpid.c:40
resultvar = <optimized out>
oldtype = 0
result = <optimized out>
#1 0x00000000004ec607 in qgisCrash(int) ()
No symbol table info available.
#2 <signal handler called>
No locals.
#3 0x00007fcb58e32ca7 in QMetaObject::methodOffset() const () from
/usr/lib/x86_64-linux-gnu/libQtCore.so.4
All the best, and thanks.
Paolo Cavallini - Faunalia
www.faunalia.eu
Full contact details at www.faunalia.eu/pc
Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.15 (GNU/Linux)
Comment: Using GnuPG with Icedove - http://www.enigmail.net/
iEYEARECAAYFAlJhTT8ACgkQ/NedwLUzIr6mqgCZAf3Ki6Ql+6wg/QAw1439hRNa
sJYAn0BR9zNOndp2Xqz/pOKWUzL7zhke
=XrM7
-----END PGP SIGNATURE-----
