[Qgis-developer] Microsoft Visual C++ Crash when build qgis 1.8.0 on Windows 7 64bit
Mohamed fkili mohamedf at globalsolgroup.com
Fri Oct 18 11:24:27 PDT 2013
  Hello Qgis developers
I have a problem building the source of qgis1.8.0 in Windows 7 64bit. i am
trying to follow this instructions in this page:
http://hub.qgis.org/wiki/17/Building_QGIS_from_Source?version=2#Building-on-
Windows the dependencys are all installed succesfully and the generation of
qgis1.8.0.sln is succesful too. but in the release solution configuration
build, always Microsoft Visual C++ crash without problem report. Anybody
know how to fix the problem with Microsoft Visual C++? Thank you.
Thank You.
Mohamed fkili
GIS Programmer
Global Solutions Group
12801 Auburn St., Detroit, MI  48223
Bus:  313.544.7117 ext. 306 -or- 313.397.8311
Fax:  313.397.8312
 <http://www.globalsolgroup.com/> www.globalsolgroup.com
Attention:
The information contained in this message and or attachments is intended
only for the person or entity to which it is addressed and may contain
confidential and/or privileged material.  Any review, retransmission,
dissemination or other use of, or taking of any action in reliance upon,
this information by persons or entities other than the intended recipient is
prohibited. If you received this in error, please contact the sender and
delete the material from any system and destroy any copies.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131018/94f5191f/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131018/94f5191f/attachment-0001.png>
