[Qgis-developer] QGIS inconsistency
    Bernd Vogelgesang
    bernd.vogelgesang at gmx.de
    Sat Oct 19 14:30:02 PDT 2013
Hi Steven,
just having a quick look at the data you provided:
- your Munros.shp doesn't have 27700 projection, but some user defined and
only becomes visible when setting to 27700 manually.
- the geojson and the shape file have quite some offset. (75 whatsoevers,
meteres, miles ??)
Apart from the fact that there might  be a bug, your data seems to me more
buggy ;)
Besides that, i never dare to do any spatial analysis within epsg 4326.
Greetz
Bernd
Am 18.10.2013, 21:13 Uhr, schrieb Steven Horner <steven at stevenhorner.com>:
> Hello,
> I have been doing a project to calculate mountain viewsheds, basically
> where a mountain summits can be seen from.
> I have calculated the viewsheds and polygonized to Vector. So far so
> good,
> but then I wanted to show which mountains could be seen from the summit
> of
> other mountains I appear to have 2 problems.
> 1. I ran a spacial query to show how many mountains (Munros) are Within
> my
> polgonized viewshed. This returns the Munros. Unfortunately I get a
> different number in QGIS 1.8 to QGIS 2.0.1, I don't know which is true
> 2. I had saved my Viewshed originally as a shapefile with a CRS of 27700
> (British National Grid), I saved a version as GeoJSON with CRS of 4326.
> If
> I run the same spacial query on this file I get a different number of
> Munros again.
> So I now have 4 different figures from what I would have expected to be
> identical.
> Is data lost when a shapefile is saved as a GeoJSON file in a different
> CRS?
> and which should I beleive 1.8 or 2.0.1 or neither?
> If anyone wants to test this you can download the files here:
> Viewshed
> Shapefile<https://dl.dropboxusercontent.com/u/2657852/AmBodach_shp.zip>-
> CRS of 27700
> Viewshed
> GeoJSON<https://dl.dropboxusercontent.com/u/2657852/AmBodach_geojson.zip>-
> Converted fromthe above but with CRS of 4326
> Munros Shapefile
> <https://dl.dropboxusercontent.com/u/2657852/Munros.zip> -
> CRS of 27700
> Wish I had realised there was something wrong before I had calculated 200
> of these.
> Thanks,
> Steven
Bernd Vogelgesang * Siedlerstrasse 2 * 91083 Baiersdorf * +49-9133-825374
