[Qgis-developer] Rv: [gdal-dev] Support of filemapping for fast rendering in QGIS...
A Huarte
ahuarte47 at yahoo.es
Tue Oct 22 05:55:01 PDT 2013
Hi, I am testing in Windows XP compiling with Visual Studio 2010.
I have a console test application using directly the "shapefil" library.
I will use test_ogrsf utility for a complete benchmark
I this environment and my test application, using OGRFastAtof(), the full read of a huge shape around 500.000 records (500mb of shp file, 150mb of dbf file) with eight double fields goes from 5.6sg to 3.06sg. I don't evaluate that the precision loss, it is a task for check.
In addition, using filemapping with boost library, the full process goes from 3.06sg to 1.45sg.
These values as you see are approximate, but they give an idea of optimization is possible at least for this OS.
It is why I wanted to check this behavior
thanks!
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131022/35988c6a/attachment.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131022/35988c6a/attachment.txt>
