[Qgis-developer] Qgis : synchronized view for photo-interpretation?
Gino Pirelli
luipir at gmail.com
Tue Oct 22 11:20:36 PDT 2013
Hi, I'm maintaining this plugin
I tested the code:
settings=QSettings()
a=settings.value( "/qgis/zoom_factor", 2, type=int )
in the python console and it works... the error message says that
cannot convert QVariant metaType = 10 (QString) in QVariant metaType = 2
(Int)... so probabily in your settings zoom_factor is set as string
value... e.g "2" instead of 2
try to check in your Qgis setting
if this is not the case, please create an issue here:
http://hub.qgis.org/projects/dockablemirrormap/issues
explaining the context and if possibile a data set to allow me to reproduce
the error?
thank you
On 22 October 2013 19:47, Zirneklitis <eko at lanet.lv> wrote:
> What could be missing? DockableMirrorMap plugin could not be started:
> An error has occured while executing Python code:
> Traceback (most recent call last):
> File "/home/karlo/.qgis2/python/**plugins/DockableMirrorMap/**dockableMirrorMapPlugin.py",
> line 79, in runDockableMirror
> wdg = DockableMirrorMap(self.iface.**mainWindow(), self.iface)
> File "/home/karlo/.qgis2/python/**plugins/DockableMirrorMap/**dockableMirrorMap.py",
> line 39, in __init__
> self.mainWidget = MirrorMap(self, iface)
> File "/home/karlo/.qgis2/python/**plugins/DockableMirrorMap/**mirrorMap.py",
> line 40, in __init__
> self.setupUi()
> line 65, in setupUi
> zoomFactor = settings.value( "/qgis/zoom_factor", 2, type=int )
> TypeError: unable to convert a QVariant of type 10 to a QMetaType of type 2
> Python version:
> 2.7.3 (default, Aug 9 2012, 17:23:57)
> [GCC 4.7.1 20120720 (Red Hat 4.7.1-5)]
> QGIS version:
> 2.1.0-Master Master, exported
> Python path: ['/usr/share/qgis/python/**plugins/processing',
> '/usr/share/qgis/python', u'/home/karlo/.qgis2/python',
> u'/home/karlo/.qgis2/python/**plugins', '/usr/share/qgis/python/**plugins',
> '/usr/lib64/python27.zip', '/usr/lib64/python2.7',
> '/usr/lib64/python2.7/plat-**linux2', '/usr/lib64/python2.7/lib-tk',
> '/usr/lib64/python2.7/lib-old'**, '/usr/lib64/python2.7/lib-**dynload',
> '/usr/lib64/python2.7/site-**packages', '/usr/lib64/python2.7/site-**packages/PIL',
> '/usr/lib64/python2.7/site-**packages/geos', '/usr/lib64/python2.7/site-**packages/gst-0.10',
> '/usr/lib64/python2.7/site-**packages/gtk-2.0',
> '/usr/lib64/python2.7/site-**packages/wx-2.8-gtk2-unicode',
> '/usr/lib/python2.7/site-**packages', '/usr/lib/python2.7/site-**
> packages/setuptools-0.6c11-**py2.7.egg-info', '/home/karlo/.qgis2/python/*
> *plugins/DigitizingTools/tools'**, '/usr/share/qgis/python/**
> plugins/fTools/tools']
> Best regards,
> Karlis
> Paolo Cavallini wrote:
>> http://plugins.qgis.org/**plugins/DockableMirrorMap/<http://plugins.qgis.org/plugins/DockableMirrorMap/>
>> enjoy
> ______________________________**_________________
> Qgis-developer mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131022/a8885d03/attachment.html>
