[Qgis-developer] QGIS context help
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Wed Oct 23 09:58:53 PDT 2013
On the issue of which format to use, pandoc can translate between most
document formats it seems, including the ones specified by Alexander as
being used by QGIS. Project is here:
http://johnmacfarlane.net/pandoc/
The help should definitely be in a single format; ideally something that is
easily editable by non-technical users.
Cheers,
Jonathan
On 23 October 2013 17:55, Paolo Cavallini <cavallini at faunalia.it> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Il 23/10/2013 18:51, Alexander Bruy ha scritto:
> > Keeping context help up-to-date requires additional efforts and
> > maybe separate team. Maybe it is better to drop context help in
> > favor of documentation? Opinions?
> IMHO we should unify the two. The context help should appear as a box
> in the manual, and the GUI should take it from there (one source,
> copied both in the GUI and in the manual).
> Thanks.
> Paolo Cavallini - Faunalia
> www.faunalia.eu
> Full contact details at www.faunalia.eu/pc
> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.14 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> iEYEARECAAYFAlJn/4AACgkQ/NedwLUzIr7IagCdFTxhUI37jtzwH7Jx1w6gsf74
> b4sAnRhjHREod8xKIOPnfuUAqfn4ra/Q
> =5CIq
> -----END PGP SIGNATURE-----
> Qgis-developer mailing list
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131023/63d4c10a/attachment.html>
