[Qgis-developer] Labels: Title Case
Alister
alister.hood at gmail.com
Wed Oct 23 14:05:06 PDT 2013
> Date: Wed, 23 Oct 2013 17:57:18 +0200
> From: Paolo Cavallini <cavallini at faunalia.it>
> To: "G. Allegri" <giohappy at gmail.com>
> Cc: qgis-developer <qgis-developer at lists.osgeo.org>
> Subject: Re: [Qgis-developer] Labels: Title Case
> Message-ID: <5267F1DE.7050604 at faunalia.it>
> Content-Type: text/plain; charset=ISO-8859-1
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Il 23/10/2013 17:50, G. Allegri ha scritto:
>> Paolo, I can't see Title Case option in QGIS 2.0.1. Is it in dev?
> Type case > Capitalize first letter (IT translation should be improved
> BTW).
> So I would expect Upper case, whereas I have UPPERCASE.
Regardless of whether it is called "capitalise first letter" or "title case", I think the current behaviour is better, because it preserves acronyms in upper case. If you want to force every word into title case you can always use an expression to convert to lower case first.
What I actually think is unfortunate is that the expression function "title()" does what you want. It would be more useful if it worked the same way as the label formatting option that you're complaining about ;)
Regards,
Alister
