[Qgis-developer] September 1 branch for release
Andreas Neumann a.neumann at carto.net
Mon Sep 2 07:33:34 PDT 2013
Hi Larry,
> I would love to know how that is possible. I've not seen a setup that
> doesn't exhibit the issue yet. Maybe it slight enough that you just don't
> 'see' it on manual visual inspection. Can you possibly run the current
> limited labeling server test from the build dir on that machine (or one
> with access to that web server)?
> It is run individually with: ctest -R PyQgsPalLabelingServer -V
I was trying to run the tests but am missing the test-projects - where
can I get them or where are they located?
I changes $HOME/.qgis2/qgis_local_server.cfg but don't know where I
should point the "projdir" variable to.
Thanks,
Andreas
