[Qgis-developer] No fix for 2.0 for #8068, wrong font display in qgis server
rldhont
rldhont at gmail.com
Tue Sep 3 01:35:47 PDT 2013
Hi Tim,
What about the 6 others blockers ?
2 seem close to resolution : #8487 and #7441
Regards,
René-Luc D'Hont
3Liz
Le 03/09/2013 10:20, Tim Sutton a écrit :
> Hi
> On Tue, Sep 3, 2013 at 5:40 AM, Larry Shaffer <larrys at dakotacarto.com
> <mailto:larrys at dakotacarto.com>> wrote:
> Hi,
> After many hours of visual testing, monkeying with the code and
> generally banging my head against a wall, I've come to the
> conclusion I can not commit the partial fix I have for this issue
> [0] without possibly causing issues in other types of output:
> canvas, composer, PDF, etc. Part of this is due to the way I coded
> the new label components and now it looks like there is definitely
> something screwy with the way server handles fonts. There are too
> many variables and no really useful unit test suite yet.
> I suggest the following course of action:
> 1) Release the desktop version with this as a known blocker,
> albeit mostly related to server output.
> 2) Have an experienced dev review the label painting code who is
> familiar with both labeling and server, e.g. Marco H., etc.
> 3) While the code is being reviewed, I can work towards finishing
> the initial unit test suite for labeling (with crosschecks between
> canvas and composer, server outputs). Absolutely no labeling
> features are added or bug fixes committed until there is a
> functioning test suite for the most common labeling uses and outputs.
> 4) When this issue is appropriately fixed and tested, look at
> possibly releasing an updated server component/pkg, if needed.
> [0] http://hub.qgis.org/issues/8068
> Thanks Larry. If there are no other objects I will go ahead with
> branching for release tonight.
> Regards
> Tim
> Regards,
> Larry Shaffer
> Dakota Cartography
> Black Hills, South Dakota
> Qgis-developer mailing list
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Irc: timlinux on #qgis at freenode.net <http://freenode.net>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130903/e0e44ef8/attachment.html>
