[Qgis-developer] SLD export problems GraphicFill element
Yewondwossen Assefa
assefay at gmail.com
Tue Sep 3 09:26:13 PDT 2013
Following up on this, I have created a new issue
http://hub.qgis.org/issues/8567 and added a patch to the issue tracker
to correct the problem. I have tested it locally and It gives the
expected result. The fix is trivial. if someone has time and commit
rights, It would be nice to get it fixed.
Thanks
regards,
Y. Assefa
On 13-08-30 02:40 PM, Yewondwossen Assefa wrote:
> Hi,
> I had posted on the user list some issues I was having when exporting
> an SLD (
> http://lists.osgeo.org/pipermail/qgis-user/2013-August/023650.html)
> Pocking around the code today, I saw what might be the issue with the
> generation of "invalid" sld with graphic fill and a graphic marker:
> file qgssymbollayerv2utils.cpp function void
> QgsSymbolLayerV2Utils::fillToSld (around line 1523) :
> /* Use WellKnownName tag to handle QT brush styles. */
> wellKnownMarkerToSld( doc, graphicFillElem, patternName, fillColor,
> borderColor );
> The call to wellKnownMarkerToSld is using the graphicFillElem instead
> of the graphicElem
> This, as discribe in the previous post produces:
> <se:GraphicFill>
> <se:Graphic/>
> <se:Mark>
> </se:Mark>
> </se:GraphicFill>
> Instead of
> <se:GraphicFill>
> <se:Graphic>
> <se:Mark>
> </se:Mark>
> </se:Graphic>
> </se:GraphicFill>
> Would it be possible for someone to confirm this issue?
> regards,
> Y. Assefa
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130903/4971411b/attachment.html>
