[Qgis-developer] How to render Shapefile using QT4 & OpenGL in ubuntu
Matthias Kuhn
matthias.kuhn at gmx.ch
Tue Sep 10 00:21:41 PDT 2013
Hi Swapan,
The code should compile for ARM, as it's does for the QGIS for Android
project.
Regarding Open GL, there is probably not much experience around in this
project, but maybe someone will chime in.
And you will probably have more response, if you CC the mailing list :)
Regards,
Matthias
On Die 10 Sep 2013 07:53:09 CEST, SWAPAN GHOSH wrote:
> Dear all,
> please help me to build an application which run on mob. having ARM
> processor.
> If possible guide me with source code using qt-openGL in ubuntu to
> display , edit .shp file.
> Regards,
> Swapan
> On Sep 7, 2013 7:48 PM, "SWAPAN GHOSH" <swap.ghsh at gmail.com
> <mailto:swap.ghsh at gmail.com>> wrote:
> Dear Matthias,
> Thank you very much for helping me. I will try acording to you.
> If possible please guide me with sample source so that I can do
> it by Qt openGL in Ubuntu12.04 as I want to port this application
> to mobile with amtron processor.
> Thanks & Regards,
> Swapan
> On Sep 7, 2013 4:28 PM, "Matthias Kuhn" <matthias.kuhn at gmx.ch
> <mailto:matthias.kuhn at gmx.ch>> wrote:
> Hi Swapan,
> You can have a look at the QGIS source code on github [1]
> It is hard to tell, if it suits your needs. For rendering,
> creating and
> editing shape files you would not need to adjust the software
> at all
> and could just use it as is, without messing with the source
> code at
> all.
> There would also highly customize it to your needs by using the
> customization menu. [2] Or you could even build an own application
> using these libraries if you see a reason for doing so. [3]
> FYI: It is not using OpenGL at all (apart from the globe plugin)
> Regards,
> Matthias
> [1] https://github.com/qgis/Quantum-GIS
> [2]
> http://docs.qgis.org/1.8/html/en/docs/user_manual/introduction/qgis_configuration.html#customization
> [3]
> http://www.qgis.org/pyqgis-cookbook/intro.html#python-applications
> On Sam 07 Sep 2013 12:36:09 CEST, SWAPAN GHOSH wrote:
> > Dear all,
> > Anybody can help me to supply source code for displaying
> shapefile in
> > linux platform. A small project for render,create,edit shape
> file.
> > Thanks & Regards,
> > Swapan Ghosh
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> <mailto:Qgis-developer at lists.osgeo.org>
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
