[Qgis-developer] [Qgis-user] Format conversion QGIS 2.0
Partha Sarathi Ghose ghose.ps1 at gmail.com
Tue Sep 17 00:21:40 PDT 2013
Hello Alex,
Thank you for suggestion. I tried the suggestion you had offered. It has
worked fine. May be we just need to work this way for the time being it
seems.
Regards,
Partha
On Tue, Sep 17, 2013 at 10:51 AM, Alex Mandel <tech_dev at wildintellect.com>wrote:
>  [image: Boxbe] <https://www.boxbe.com/overview> tech at wildintellect.comis not on your
> Guest List<https://www.boxbe.com/approved-list?tc_serial=15152070884&tc_rand=1533465946&utm_source=stf&utm_medium=email&utm_campaign=ANNO_MWTP&utm_content=001&token=ZUOTYAjZSY8wLuqbl5O%2BDV5C8cYjU0miR8wr0j1C9ILA2xOSfCOxmvhkmrZwujGQ&key=9xReQuTRr%2BttfpMQsyX1TMEwj78J%2BxPjoAzxtqDi1uc%3D>| Approve
> sender<https://www.boxbe.com/anno?tc_serial=15152070884&tc_rand=1533465946&utm_source=stf&utm_medium=email&utm_campaign=ANNO_MWTP&utm_content=001&token=ZUOTYAjZSY8wLuqbl5O%2BDV5C8cYjU0miR8wr0j1C9ILA2xOSfCOxmvhkmrZwujGQ&key=9xReQuTRr%2BttfpMQsyX1TMEwj78J%2BxPjoAzxtqDi1uc%3D>| Approve
> domain<https://www.boxbe.com/anno?tc_serial=15152070884&tc_rand=1533465946&utm_source=stf&utm_medium=email&utm_campaign=ANNO_MWTP&utm_content=001&dom&token=ZUOTYAjZSY8wLuqbl5O%2BDV5C8cYjU0miR8wr0j1C9ILA2xOSfCOxmvhkmrZwujGQ&key=9xReQuTRr%2BttfpMQsyX1TMEwj78J%2BxPjoAzxtqDi1uc%3D>
> As far as I can tell, it affects all formats. You have to manually
> change the -of parameter of gdal_translate in the bottom box. At this
> point, no it will likely not be fixed in 2.0 as that's already gone to
> packaging. GDAL_tools is a python plugin though, so I'm wondering if we
> might just be able to push a fix via the python plugin manager and then
> users will be able to pick up the update.
> Thanks,
> Alex
> On 09/16/2013 07:31 PM, Partha Sarathi Ghose wrote:
> > Hi All,
> > It seems a similar problem happens when while converting to idrisi format
> > too. While the .rst extension get written, the .rdc does not get created
> > and thus in the later stages it becomes difficult to work with idrisi
> > format of files. Is there a way to take care of this issue and do you
> think
> > this would be taken care of in the final version?
> > Regards
> > Partha
> > On Mon, Sep 16, 2013 at 11:55 PM, Paolo Cavallini <cavallini at faunalia.it
> >wrote:
> >>  [image: Boxbe] <https://www.boxbe.com/overview> cavallini at faunalia.itis
> >> not on your Guest List<
> https://www.boxbe.com/approved-list?tc_serial=15148098892&tc_rand=1223463893&utm_source=stf&utm_medium=email&utm_campaign=ANNO_MWTP&utm_content=001&token=qFu%2BFusGAh%2Fu7FBmJl%2FKu2%2F0i2z5UmB0TunaHOcrAJZogGzPI%2BmcN3RBpz%2BNtrnR&key=ajCBA4GcTPbxIUZp%2BeHnNuAQlGc%2FMlFOy6uxqOJqv6w%3D>|
> Approve
> >> sender<
> https://www.boxbe.com/anno?tc_serial=15148098892&tc_rand=1223463893&utm_source=stf&utm_medium=email&utm_campaign=ANNO_MWTP&utm_content=001&token=qFu%2BFusGAh%2Fu7FBmJl%2FKu2%2F0i2z5UmB0TunaHOcrAJZogGzPI%2BmcN3RBpz%2BNtrnR&key=ajCBA4GcTPbxIUZp%2BeHnNuAQlGc%2FMlFOy6uxqOJqv6w%3D>|
> Approve
> >> domain<
> https://www.boxbe.com/anno?tc_serial=15148098892&tc_rand=1223463893&utm_source=stf&utm_medium=email&utm_campaign=ANNO_MWTP&utm_content=001&dom&token=qFu%2BFusGAh%2Fu7FBmJl%2FKu2%2F0i2z5UmB0TunaHOcrAJZogGzPI%2BmcN3RBpz%2BNtrnR&key=ajCBA4GcTPbxIUZp%2BeHnNuAQlGc%2FMlFOy6uxqOJqv6w%3D
> >> On 2013-09-16 20:17, Alex Mandel wrote:
> >>  I can confirm this bug, forwarding to the developer list. Temporary
> >>> workaround, is to press the pencil button and edit the -of part of the
> >>> command to the correct format as listed on
> http://gdal.org/formats_list.*
> >>> *html <http://gdal.org/formats_list.html>
> >>> In this case it should say "-of AAIGrid"
> >> Hi all.
> >> It looks easy to fix: would it be worth a 2.0.2 release?
> >> All the best.
Dr. Partha Sarathi Ghose,
Senior Project Officer,
WWF - India,
Khangchendzonga Landscape Programme,
Near Forest Secretariat,
Deorali,
Gangtok - 737102,
Sikkim
Mobile - +919433930859
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130917/c347ba0b/attachment-0001.html>
