[Qgis-developer] processing not finding saga
Victor Olaya volayaf at gmail.com
Tue Sep 17 03:20:11 PDT 2013
good remark.
Paolo, if that's the case, just make sure you have the correct
compatibility enabled (you should see the expected version in the
toolbox entry)
2013/9/17 Jürgen E. <jef at norbit.de>:
> Hi Paolo,
> On Tue, 17. Sep 2013 at 12:11:40 +0200, Paolo Cavallini wrote:
>> Here at FOSS4G, presenting QGIS 2.0 is going well. Unfortunately we are
>> hitting once again the problem with saga not being found by Processing.
>> This is on Windows: could it be a packaging problem? Of course we cannot
>> do much testing here: does anybody confirm?
> Are you aware that the 64bit has SAGA 2.1.0 while 32bit has SAGA 2.0.x?
> Might that be related?
> Jürgen
> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
> Software Engineer         D-26506 Norden               http://www.norbit.de
> QGIS PSC member (RM)                                   IRC: jef on FreeNode
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-developer mailing list
