[Qgis-developer] Fwd:
Tamas Szekeres
szekerest at gmail.com
Fri Sep 20 03:36:11 PDT 2013
This looks like a manifest issue. If you compile with MSVC2005/MSVC2008 the
CRT manifest file should probably be embedded as a resource in the
executables / dlls.
Best regards,
Tamas
2013/9/20 Paolo Cavallini <cavallini at faunalia.it>
> Hi all.
> Apparently this kind of problems are rather common - why not adding a
> "Troubleshooting" section to the Download page?
> All the best.
> -------- Original Message --------
> I downloaded and
> installed the 64 bit version as i'm on a sony vio running on windows 64
> - and get the following error when I try to run it. Once I hit ok it
> opens but then crashed when I tried to install a plugin.
> Paolo Cavallini - Faunalia
> www.faunalia.eu
> Full contact details at www.faunalia.eu/pc
> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/**calendario<http://www.faunalia.it/calendario>
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130920/c4657085/attachment.html>
