[Qgis-developer] Error message at start QGIS 2.0.1-1 Mac OSX
Patrice Vetsel
patrice at kagou.fr
Fri Sep 20 06:48:50 PDT 2013
After installing psycopg2 gdaltools is not happy :
Impossible de charger l'extension GdalTools provoque une erreur lors de l'appel de sa méthode initGui()
File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 213, in startPlugin
plugins[packageName].initGui()
File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/GdalTools/GdalTools.py", line 99, in initGui
from tools.GdalTools_utils import Version, GdalConfig, LayerRegistry
File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 453, in _import
mod = _builtin_import(name, globals, locals, fromlist, level)
File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/GdalTools/tools/GdalTools_utils.py", line 877, in
if platform.system() == "Darwin":
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/platform.py", line 1282, in system
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/platform.py", line 1249, in uname
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/platform.py", line 1005, in _syscmd_uname
IOError: [Errno 4] Interrupted system call
Version de Python :
2.7.2 (default, Oct 11 2012, 20:14:37)
[GCC 4.2.1 Compatible Apple Clang 4.0 (tags/Apple/clang-418.0.60)]
Version de QGIS :
2.0.1-Dufour Dufour, f738351
Chemin vers Python : ['/Applications/QGIS.app/Contents/MacOS/../Resources/python', '/Users/kagou/.qgis2/python', '/Users/kagou/.qgis2/python/plugins', '/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins', '/Library/Frameworks/SQLite3.framework/Versions/B/Python/2.7', '/Library/Python/2.7/site-packages/numpy-override', '/Library/Frameworks/GDAL.framework/Versions/1.10/Python/2.7/site-packages', '/Library/Python/2.7/site-packages/pip-1.3.1-py2.7.egg', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages', '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload', '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC', '/Library/Python/2.7/site-packages', '/Applications/QGIS.app/Contents/Resources/python/plugins/fTools/tools']
Le 20 sept. 2013 à 15:46, Patrice Vetsel <patrice at kagou.fr> a écrit :
> Seems that psycopg2 had to be installed too.
> Regards
> Le 20 sept. 2013 à 15:44, Patrice Vetsel <patrice at kagou.fr> a écrit :
>> From http://www.kyngchaos.com/software/qgis
>> After installing latest gdal complete and QGIS 2.0.1-1 for Lion & Mt Lion
>> at first launch i'v these messages :
>> Impossible de charger l'extension 'processing' depuis ['/Applications/QGIS.app/Contents/MacOS/../Resources/python', '/Users/kagou/.qgis2/python', '/Users/kagou/.qgis2/python/plugins', '/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins', '/Library/Frameworks/SQLite3.framework/Versions/B/Python/2.7', '/Library/Python/2.7/site-packages/numpy-override', '/Library/Frameworks/GDAL.framework/Versions/1.10/Python/2.7/site-packages', '/Library/Python/2.7/site-packages/pip-1.3.1-py2.7.egg', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages', '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload', '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC', '/Library/Python/2.7/site-packages', '/Applications/QGIS.app/Contents/Resources/python/plugins/fTools/tools']
>> File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 182, in loadPlugin
>> __import__(packageName)
>> File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/__init__.py", line 20, in
>> from processing.tools.general import runalg, runandload, alghelp, alglist, algoptions, load, extent, getobject
>> File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/tools/general.py", line 29, in
>> from processing.core.Processing import Processing
>> File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/core/Processing.py", line 52, in
>> from processing.admintools.AdminToolsAlgorithmProvider import AdminToolsAlgorithmProvider
>> File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/admintools/AdminToolsAlgorithmProvider.py", line 19, in
>> from processing.admintools.PostGISExecuteSQL import PostGISExecuteSQL
>> File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/admintools/PostGISExecuteSQL.py", line 32, in
>> from processing.admintools import postgis_utils
>> File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/admintools/postgis_utils.py", line 39, in
>> import psycopg2
>> ImportError: No module named psycopg2
>> Version de Python :
>> Version de QGIS :
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130920/6e3242fa/attachment.html>
