[Qgis-developer] Processing>grass broken on win64?
Victor Olaya
volayaf at gmail.com
Sat Sep 21 01:26:45 PDT 2013
Just tried here with a fresh 64bit installer for win. It works fine
and it autodetect the path to GRASS in
"C:/PROGRA~1/QGISDU~1/apps\grass\grass-6.4.3"
Question for Giovanni: maybe it might be that in your system it has
something like "c:/Program files/..." (including white spaces)?. That
should explain the issue.
Can you check in the setttings/providers/grass, the value of the grass
folder parameter, and tell me what it looks like?
Let's see if we can fix this quickly
Thanks!
2013/9/20 Paolo Cavallini <cavallini at faunalia.it>:
> On 2013-09-20 11:09, Giovanni Manghi wrote:
>> I have reported this issue several days ago: in the standalone
>> packages grass/processing does not work, it does work on osgeo4w.
> is this in 2.0.1? does grass plugin work? is this true for 32 and 64 bit
> win?
> Thanks.
> Paolo Cavallini - Faunalia
> www.faunalia.eu
> Full contact details at www.faunalia.eu/pc
> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
> Qgis-developer mailing list
