[Qgis-developer] QGIS 2.0 and GRASS integration on OSX and Windows
Andreas Neumann
a.neumann at carto.net
Wed Sep 25 02:14:26 PDT 2013
I did more testing and it seems that on Windows, both 32bit and 64bit
versions are fine if I install from OSGeo4W. However, both fail if I
install from the standalone installer. This is in line with what other
people discovered.
Running, QGIS as administrator does not help in my case.
According to Jürgen both come from the same sources, so it is really a
myth why the standalone installer does not support GRASS in processing,
and OSGeo4W does support it.
Maybe there is some missing dependency in the standalone installer? The
standalone installer probably does not include all packages that can be
selected in the OSGeo4W installer?
Andreas
Am 24.09.2013 12:15, schrieb Giovanni Manghi:
>> Most of our Windows users seem to get a very similar behavior.
> Hi Andreas,
> as pointed in the past days in another thread it seems that in the
> qgis 2.0 standalone installers for Windows GRASS/processing is not
> working. SAGA/processing it is also not working but in this case SAGA
> does not seems included at all.
> They both work if QGIS is installed with osgeo4w.
> cheers
> -- Giovanni --
> Qgis-developer mailing list
