[Qgis-developer] WMS info causes frequent crashes
Paolo Cavallini
cavallini at faunalia.it
Fri Sep 27 02:49:14 PDT 2013
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Anyone confirms? It happens a lot here.
Some info:
warning: Could not load shared library symbols for linux-vdso.so.1.
Do you need "set solib-search-path" or "set sysroot"?
[New LWP 23523]
[New LWP 23522]
[New LWP 23516]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
warning: no loadable sections found in added symbol-file system-supplied DSO at
0x7fffae7fe000
0x00007f4e1d9d40f7 in __libc_waitpid (pid=<optimized out>, stat_loc=<optimized out>,
options=<optimized out>) at ../sysdeps/unix/sysv/linux/waitpid.c:40
40 ../sysdeps/unix/sysv/linux/waitpid.c: File o directory non esistente.
[Current thread is 1 (Thread 0x7f4e25044780 (LWP 23515))]
#0 0x00007f4e1d9d40f7 in __libc_waitpid (pid=<optimized out>, stat_loc=<optimized
out>, options=<optimized out>) at ../sysdeps/unix/sysv/linux/waitpid.c:40
resultvar = <optimized out>
oldtype = 0
result = <optimized out>
#1 0x00000000004ec607 in qgisCrash(int) ()
All the best.
Paolo Cavallini - Faunalia
www.faunalia.eu
Full contact details at www.faunalia.eu/pc
Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.14 (GNU/Linux)
Comment: Using GnuPG with Icedove - http://www.enigmail.net/
iEYEARECAAYFAlJFVJoACgkQ/NedwLUzIr4fYACeMcJfZnhtKzC7hB9qPrwCIez6
yFQAn3dKIu8UN6yU3I/E+yN5zJBTFU1G
=yUod
-----END PGP SIGNATURE-----
