[Qgis-developer] install instructions
stevenhorner
steven at stevenhorner.com
Fri Sep 27 12:25:01 PDT 2013
Etienne Tourigny-3 wrote
> On Fri, Sep 27, 2013 at 4:11 PM, stevenhorner <
> steven@
> >wrote:
>> I had similar problems installing on raring, like you I had both listed,
>> but
>> now use these instructions disable any other source you may have added:
>> sudo apt-get install python-software-properties
>> sudo add-apt-repository ppa:ubuntugis/ubuntugis-unstable
>> sudo apt-get update
>> sudo apt-get install qgis python-qgis qgis-plugin-grass
>> This installs but you may get an error when starting QGIS on Ubuntu which
>> is
>> normally because the owner of the .QGIS2 folder is Root rather than your
>> logon user. You may need to change this.
> I experienced the same problem (.qgis2 folder created by root). Is that
> folder created by qgis installation? Probably, but very odd.
> This is a BIG bug and should be fixed, is there a bug report on this?
> Etienne
Yes it's on the issue list here: http://hub.qgis.org/issues/8613
<http://hub.qgis.org/issues/8613>
View this message in context: http://osgeo-org.1560.x6.nabble.com/install-instructions-tp5080617p5080633.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
