[Qgis-developer] OS X 2.0 packages update
    William Kyngesburye
    woklist at kyngchaos.com
    Sat Sep 28 08:41:30 PDT 2013
I understand.  And I'm saying that that link error (and many others) is fixed in the current build.  You don't need anything else installed for OTB to work, OTB and the libraries/frameworks linked are included in QGIS.app.
Note that when I re-fixed the installer I didn't bump the version number (because the broken package was still the old package), so make sure to download it again.
On Sep 27, 2013, at 8:49 PM, Noli Sicad wrote:
> Hi William,
> In the last screenshot on the OTB Plugin for QGIS 2.0.1-2 Mac OS X
> error that I sent you, it seems that there is dynamic library that is
> not loading.
> "dylb: Library not loaded" (in the screenshot error)
> In compiling OTB Plugin for QGIS 2.0.1-2 Mac OS X, does OTB-Plugin
> requires OTB binary installed in your system?
> What might be this dynamic library not loading, (i.e. what is this library)?
> I hope we can make OTB plugin working in Mac OS X.
> Thanks,
> Regards, Noli
> On 9/25/13, Noli Sicad <nsicad at gmail.com> wrote:
>> I deleted QGIS.app before installing.
>> I deleted QGIS.app again and reinstalled. Yet I got the same problem,
>> OTB is not working as showed in the screenshot that I sent you.
>> Noli
>> On 9/25/13, William Kyngesburye <woklist at kyngchaos.com> wrote:
>>> Again, very odd, it's correct in the installer package.  Try deleting
>>> QGIS.app and reinstalling.
>>> On Sep 25, 2013, at 8:45 AM, Noli Sicad wrote:
>>>> Hi William,
>>>> The OTB plugin is still not working in this update.
>>>> I will send you a screenshot of the error.
>>>> Noli
>>>>> Very odd, the package has this library link correct.  Try deleting
>>>>> QGIS.app
>>>>> and reinstalling.
>>>>> On Sep 25, 2013, at 3:24 AM, Andreas Neumann wrote:
>>>>>> Hi William,
>>>>>> Thank you for your continuous support on this issue.
>>>>>> Unfortunately, GRASS still does not work in my processing environment.
>>>>>> It
>>>>>> still complains about missing dependencies.
>>>>>> In parallel to Processing I am also testing the GRASS plugin.
>>>>>> I can successfully create new MAPSETs and open them. The modules are
>>>>>> found, but when loading one, e.g. v.surf.rst, I get this error
>>>>>> message:
>>>>>> Kann Modul v.surf.rst nicht starten
>>>>>> DYLD_LIBRARY_PATH=
>>>>>> QGIS_PREFIX_PATH=
>>>>>> Befehl: /Applications/QGIS.app/Contents/MacOS/grass/bin/v.surf.rst
>>>>>> --interface-description
>>>>>> dyld: Library not loaded: /usr/local/lib/libfftw3.3.dylib Referenced
>>>>>> from:
>>>>>> /Applications/QGIS.app/Contents/MacOS/grass/lib/libgrass_gmath.6.4.3.dylib
>>>>>> Reason: image not found
>>>>>> so it seems to complain about "libfftw3.3.dylib"
>>>>>> Andreas
>>>>>> On Tue, 24 Sep 2013 20:24:55 -0500, William Kyngesburye wrote:
>>>>>>> I did a link hunt and fixed up all the link errors I could find, and
>>>>>>> took care of some other packaging problems.
>>>>>>> Also, Snow Leopard package is now ready.
>>>>>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>>>>>> http://www.kyngchaos.com/
>>>>>>> "History is an illusion caused by the passage of time, and time is an
>>>>>>> illusion caused by the passage of history."
>>>>>>> - Hitchhiker's Guide to the Galaxy
>>>>>>> _______________________________________________
>>>>>>> Qgis-developer mailing list
>>>>>>> Qgis-developer at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> First Pogril: Why is life like sticking your head in a bucket filled with
>>> hyena offal?
>>> Second Pogril: I don't know.  Why IS life like sticking your head in a
>>> bucket filled with hyena offal?
>>> First Pogril: I don't know either.  Wretched, isn't it?
>>> -HitchHiker's Guide to the Galaxy
First Pogril: Why is life like sticking your head in a bucket filled with hyena offal?
Second Pogril: I don't know.  Why IS life like sticking your head in a bucket filled with hyena offal?
