[Qgis-developer] composer questions
    Denis Rouzaud
    denis.rouzaud at gmail.com
    Mon Sep 30 04:54:04 PDT 2013
I have two questions regarding the print composer:
- is there anyway of using some fields to determine the printed bounding
box instead of using the feature's geometry?
if no, do you think it could be an interesting feature?
- While trying to use overview map, it did not print the correct
location (it used a previous area).
  Is this normal?
Does this depend on the mode of rendering (render vs rectangle)?
Thanks a lot,
Denis
