[Qgis-developer] hub.qgis.org
Werner Macho
werner.macho at gmail.com
Tue Apr 1 02:07:09 PDT 2014
hmmm
I've seen we've 41 security updates on that server pending
and 11 package updates including apache2
among security updates there are mysql and postgis..
I don't know if it safe to just upgrade them (as I don't know if one
of the installed software requires a specific version)
But probably updating could help?
I am not sure
regards
Werner
On Tue, Apr 1, 2014 at 11:00 AM, Alex Mandel <tech_dev at wildintellect.com> wrote:
> It's a combination of disk filling and a ruby memory leak/stuck process.
> Concerning the disk, cleanup began last week of various things including
> moving the plugins site. Not sure why it filled up again so fast.
> Concerning the ruby issue. There is a cron job that is supposed to be
> killing out of control processes but it doesn't seem to work anymore.
> I don't know who wrote it:
> /usr/local/sbin/weigh-passengers
> But we can probably make it more aggressive, or someone can make sure
> it's actually running like its supposed to. The cron job does not appear
> to be running every 5 minutes like used to.
> Richard is working on longer term balancing.
> Thanks,
> Alex
> On 04/01/2014 01:37 AM, Andreas Neumann wrote:
>> Hi,
>> I am trying to report a bug, but http://hub.qgis.org/ does not work.
>> I get:
>> Application error
>> Rails application failed to start properly
>> Already last week at the hackfest I had troubles with hub.qgis.org -
>> sometimes it worked, sometimes it fails. Can we do something so that
>> this becomes more reliable?
>> Thanks a lot,
>> Andreas
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
