[Qgis-developer] Point sampling tool
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Thu Apr 3 05:49:59 PDT 2014
Hi Paolo
I have used Point Sampling tool in the past and it is a bit slow for large
number of points. Ideally will be great to have this:
http://gis-lab.info/qa/extract-values-rasters-eng.html
(works only for rasters)
in the processing.
Cheers,
Saber
-----Original Message-----
[mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Paolo Cavallini
Sent: 03 April 2014 13:24
To: qgis-developer
Subject: [Qgis-developer] Point sampling tool
Hi all.
Is there any good reason not to include Point sampling tool plugin in
Processing?
Thanks.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
such checks as you feel appropriate.
If this email contains a quote or offer to sell products, carry out work or perform services then our standard terms and conditions (which can be found at http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf shall apply unless explicitly stated otherwise.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
