[Qgis-developer] WMS Legend in QGIS 2.2
Gino Pirelli
luipir at gmail.com
Fri Apr 4 00:02:59 PDT 2014
I forgot to say that if a legendGraphic is available is shown under the
layer in LegendLayer... it's really little and you have to click on it to
open in real dimension (this is due to QgsLegendInterface architectural
limitation)
Legend will be integrated in composer at it's original (dowloaded) dimension
graphic resolution of the legend could be set in options-Canvas &
Legend->WMS getLegendGraphic resolution to match your printing requirements
On 4 April 2014 08:46, Gino Pirelli <luipir at gmail.com> wrote:
> should retrieve legend if WMS server has getLegendGraphic capability and
> layer has getCapability url specified... so you HAVE to select a
> styling. Otherwise, silently do nothing as before when getLegendGraphic
> integration wasn't available.
> just tested on your server and it works
> ciao Luigi Pirelli (luigi.pirelli at faunalia.it - luipir at gmail.com)
> On 4 April 2014 07:44, Tim Sutton <lists at linfiniti.com> wrote:
>> Hi
>> In the 2.2 release notes, we list the ability to show WMS legend in TOC
>> and composer[1]. Can someone provide instructions on how to actually do
>> this - I don't see any obvious way to get it working.
>> I tested using the fires from the last 48 hours layer at [2].
>> Regards
>> Tim
>> [1] http://changelog.linfiniti.com/qgis/version/21/#108
>> [2] http://global.afis.co.za/geoserver/wms
>> Tim Sutton - QGIS Project Steering Committee Member
>> Please do not email me off-list with technical
>> support questions. Using the lists will gain
>> more exposure for your issues and the knowledge
>> surrounding your issue will be shared with all.
>> Irc: timlinux on #qgis at freenode.net
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140404/1fe32081/attachment.html>
