[Qgis-developer] Deactivating multi-threaded rendering - Was: QGIS' TimeManager plugin in action
Mathieu Pellerin nirvn.asia at gmail.com
Sat Apr 5 20:51:41 PDT 2014
Seems code will have to move away from a timer and instead trigger
rendering on determined timeout which will trigger another timeout upon
renderJobFinish if timemanager is playing / exporting.
MRT has greatly improved interaction with timemanager time slider btw.
M
On 6 Apr 2014 05:30, "Anita Graser" <anitagraser at gmx.at> wrote:
> Am 06.04.2014, 00:08 Uhr, schrieb Nathan Woodrow <madmanwoo at gmail.com>:
>  Yeah there is a renderComplete() or renderJobFinsihed.  I think you need
>> to
>> use renderJobFinished.
> Thanks!
> The process is currently controlled by a timer object. Do you know what's
> best practice to combine a time + waiting for a signal?
> Best wishes,
> Anita
>> - Nathan
>> On Sun, Apr 6, 2014 at 8:05 AM, Anita Graser <anitagraser at gmx.at> wrote:
>>  Hi Nathan,
>>> Am 05.04.2014, 22:54 Uhr, schrieb Nathan Woodrow <madmanwoo at gmail.com>:
>>>  What iisues do you have with your time manager and MTR?
>>> The export image series does not work properly anymore: it sometimes
>>> saves
>>> before the map is done rendering.
>>> Maybe there's some signal I could use?
>>> Best wishes,
>>> Anita
>>>  t>>
>>>  Nathan
>>>> On 06/04/2014 1:11 am, "Anita Graser" <anitagraser at gmx.at> wrote:
>>>>  Hi,
>>>>> Are there plans to let plugins (which are not working well with
>>>>> multi-threaded rendering) deactivate the feature when needed?
>>>>> Thanks and best wishes,
>>>>> Anita
>>>>> Am 04.04.2014, 05:44 Uhr, schrieb Mathieu Pellerin <
>>>>>  Hmm, is there no way to deactivate MTR? As far as I understand, while
>>>>> we
>>>>>> can de-activate multi-core rendering, the general multi-threaded
>>>>>> rendering
>>>>>> can't be turned off.
>>>>>> On Thu, Apr 3, 2014 at 7:32 PM, Anita Graser <
>>>>>> anita.graser.at at gmail.com
>>>>>> wrote:
>>>>>>  Hi Mathieu,
>>>>>>> I'm aware of some issues caused by multi-threaded rendering. If
>>>>>>> deactivated, TimeManager should work as always. I currently don't
>>>>>>> have
>>>>>>> time to look into adjusting it to the multi-threaded rendering.
>>>>>>> Best wishes,
>>>>>>> Anita
>>>>>>> On Thu, Apr 3, 2014 at 2:02 AM, Mathieu Pellerin <
>>>>>>> wrote:
>>>>>>> > Any progress upgrading timemanager to be qgis 2.3 compatible?
>>>>>>> > On 2 Apr 2014 23:34, "Anita Graser" <anita.graser.at at gmail.com>
>>>>>>> wrote:
>>>>>>> >> Hi Mathieu,
>>>>>>> >> Thanks for sharing! That's a really well done video on a difficult
>>>>>>> topic.
>>>>>>> >> I've added it to the Time Manager Youtube playlist as well.
>>>>>>> >> Best wishes,
>>>>>>> >> Anita
>>>>>>> >> Am 01.04.2014, 08:41 Uhr, schrieb Mathieu Pellerin <
>>>>>>> nirvn.asia at gmail.com>:
>>>>>>> >>> Greetings Anita,
>>>>>>> >>> I've just finished a spacial project that relied on your
>>>>>>> TimeManager
>>>>>>> >>> plugin
>>>>>>> >>> to produce a time-lapse of recorded land conflicts in Cambodia
>>>>>>> over
>>>>>>> 13
>>>>>>> >>> years: http://licadho-cambodia.org/video.php?perm=46
>>>>>>> >>> Sharing as I think you might appreciate seeing the great fruits
>>>>>>> your
>>>>>>> tool
>>>>>>> >>> can produce.
>>>>>>> >>> Cheers,
>>>>>>> >>> Math
>>>>>>> >> anitagraser.com
>>>>> anitagraser.com
>>>>> _______________________________________________
>>>>> Qgis-developer mailing list
>>>>> Qgis-developer at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> anitagraser.com
> anitagraser.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140406/eca896e7/attachment-0001.html>
