[Qgis-developer] Adding plugins to core?
Mathieu Pellerin
nirvn.asia at gmail.com
Mon Apr 7 03:15:59 PDT 2014
Also, when it comes to OSM, IMO proper TMS support should be what is
(eventually) offered as implemented feature to users. That'd allow for OSM
basemaps to also export properly in qgis composer. OpenLayer' layers not
exporting well in qgis composer is a pretty big limitation.
Maybe a simple UI to wrap around GDAL's internal TMS support?
M
On Mon, Apr 7, 2014 at 5:05 PM, Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On 7 April 2014 18:15, Vincent Picavet <vincent.ml at oslandia.com> wrote:
> > A good solution though would be to remove google layers and only use OSM
> and
> > mapbox layers, which begin to be on par in terms of quality.
> I'm pretty sure this is against MapBox's terms of service too, unless
> users were made to sign up for a MapBox account and had to add their
> individual API key to QGIS to unlock MapBox layers:
> "You must have a Mapbox account to use Mapbox. You are required to
> register for an account before using the Service. Each request to the
> API must include your account's unique API identifier. Unauthorized
> use of any API identifier is prohibited." [1]
> > Or let the user a
> > deliberate way to add google layers (indicating a URL or something like
> this),
> > warning him about the licence.
> Hmm... while this may be a workable solution to the licensing issue,
> wouldn't it be a step back in functionality anyway? We'd be trading
> having a good, working off-the-shelf third-party plugin for a crippled
> core version which takes user intervention to unlock the same
> features.
> I'm totally for adding essential plugins to core (or merging the
> functionality with reimplemented c++ versions), but I honestly don't
> know if it's workable to do this for the OpenLayers plugin.
> Nyall
> [1] https://www.mapbox.com/tos/
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140407/0af0739b/attachment.html>
