[Qgis-developer] Tickets about Processing
Alexander Bruy
alexander.bruy at gmail.com
Mon Apr 7 06:38:51 PDT 2014
If I understand correctly, this is redmine limitation. Alex can
clarify this better then me
There is also another option — move all Processing tickets
into main QGIS tracker. But in this case we will lose all ticket
groups and will have only one group called "Processing".
2014-04-07 16:35 GMT+03:00 Paolo Cavallini <cavallini at faunalia.it>:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Il 07/04/2014 15:30, Alexander Bruy ha scritto:
>> now Processing is as subproject of QGIS (thanks to Alex Mandel).
>> All Processing tickets now should be visible in QGIS bugtracker, also
>> you can use custom query on the right panel [0] to filter only Processing
>> tickets.
>> If you need to create new ticket for Processing, you need to use its
>> bugtracker [1], as for now there is no way to create ticket in subproject
>> from main tracker.
> Thanks for clarifying.
> What is the reason for this complexity?
> All the best.
> Paolo Cavallini - www.faunalia.eu
> Corsi QGIS e PostGIS: http://www.faunalia.eu/training.html
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1
> Comment: Using GnuPG with Icedove - http://www.enigmail.net/
> iEYEARECAAYFAlNCqawACgkQ/NedwLUzIr4BBQCgk9bvL4lwQa32Q1fAfoUBpz2C
> MPYAoKaQbfAFzg38G3WfO5+3h8anTHjw
> =ttF8
> -----END PGP SIGNATURE-----
Alexander Bruy
