[Qgis-developer] Adding plugins to core?
Olivier Dalang
olivier.dalang at gmail.com
Mon Apr 7 11:05:11 PDT 2014
Hi !
I agree with those saying it's better to integrate the features of
top-plugin in the core, if we find the features are worth it, and if
someone has the time to do so, rather than shipping dozens of preinstalled
plugin.
I don't like the impression it gives to have a brand new software already
"bloated" by plugins, which you never really know what they do and if it's
OK or not to remove them.
A better alternative IMO is to display the "featured" plugins category as a
tab in the plugin manager, but not to preinstall them.
It could even become the default page of the plugin manager.
I personally feel much better when adding by myself suggested plugins than
when hesitating to remove a plugin which I'm not really sure what it's
about but seems kinda-important since it already was installed...
About this, please consider this ticket also :
http://hub.qgis.org/issues/9405
Cheers !
Olivier
2014-04-07 19:41 GMT+02:00 Etienne Tourigny <etourigny.dev at gmail.com>:
> Thanks for the links. Most of this information is also available at [1].
> I am preparing a simple plugin to load these layers as raster layers,
> will keep you updated on this.
> [1] http://www.gdal.org/frmt_wms.html
> On Mon, Apr 7, 2014 at 2:32 PM, kimaidou <kimaidou at gmail.com> wrote:
>> Hi List
>> For the record, here is an old blog post about using gdal driver to
>> use external layers such as OSM
>> http://www.3liz.com/blog/rldhont/index.php?post/2012/07/17/OpenStreetMap-Tiles-in-QGIS
>> The problem is that with this method, it seems GDAL does not alway use
>> the right tiles for the rigth scale. There must be an additionnal
>> parameter wich can control this behaviour.
>> I totally agree with the concerns about licence violation. Easing the
>> use of Google layers is kind of encouraging people to use it, for
>> example for digitization purpose. Users must be warned about the terms
>> of service.
>> Michael
>> PS : someone has gathered a list of XML for GDAL for some providers :
>> http://libreavous.teledetection.fr/geomatique/28-sig/58-afficher-des-couches-issues-de-services-en-ligne-dans-un-sig
>> Click on the button called "Fichiers de configuration ...."
>> Michael
>> 2014-04-07 16:48 UTC+02:00, Etienne Tourigny <etourigny.dev at gmail.com>:
>> > Since the OpenLayers plugin does not (currently) work with master,
>> perhaps
>> > we can replace it with TMS-based layers, either through a plugin or as a
>> > native (GDAL-based) provider?
>> > Is there anything in OpenLayers plugin that could not work with GDAL TMS
>> > mini-driver [1] ?
>> > On Mon, Apr 7, 2014 at 11:42 AM, Etienne Tourigny
>> >> perhaps
>> >> we can replace it with TMS-based layers, wither through a plugin or as
>> a
>> >> Is there anything in OpenLayers that could not work with GDAL TMS
>> >> mini-driver [1] ?
>> >> On Mon, Apr 7, 2014 at 7:22 AM, Vincent Picavet
>> >> <vincent.ml at oslandia.com>wrote:
>> >>> Hello,
>> >>> Le lundi 7 avril 2014 12:05:05, Nyall Dawson a écrit :
>> >>> > On 7 April 2014 18:15, Vincent Picavet <vincent.ml at oslandia.com>
>> >>> > wrote:
>> >>> > > A good solution though would be to remove google layers and only
>> use
>> >>> OSM
>> >>> > > and mapbox layers, which begin to be on par in terms of quality.
>> >>> > I'm pretty sure this is against MapBox's terms of service too,
>> unless
>> >>> > users were made to sign up for a MapBox account and had to add their
>> >>> > individual API key to QGIS to unlock MapBox layers:
>> >>> > "You must have a Mapbox account to use Mapbox. You are required to
>> >>> > register for an account before using the Service. Each request to
>> the
>> >>> > API must include your account's unique API identifier. Unauthorized
>> >>> > use of any API identifier is prohibited." [1]
>> >>> Right, I had not read this through. It would probably be much easier
>> to
>> >>> get a
>> >>> specific authorization from MapBox than from Google though, given
>> their
>> >>> open-
>> >>> source orientation.
>> >>> > > Or let the user a
>> >>> > > deliberate way to add google layers (indicating a URL or something
>> >>> like
>> >>> > > this), warning him about the licence.
>> >>> > Hmm... while this may be a workable solution to the licensing issue,
>> >>> > wouldn't it be a step back in functionality anyway? We'd be trading
>> >>> > having a good, working off-the-shelf third-party plugin for a
>> crippled
>> >>> > core version which takes user intervention to unlock the same
>> >>> > features.
>> >>> In any case, there are quite a lot of OSM based layers which can be
>> used
>> >>> (HOT,
>> >>> OSM.fr, OpenCycleMap...). We can still enhance the plugin with those.
>> >>> It would lack an aerial imagery layer though.
>> >>> > I'm totally for adding essential plugins to core (or merging the
>> >>> > functionality with reimplemented c++ versions), but I honestly don't
>> >>> > know if it's workable to do this for the OpenLayers plugin.
>> >>> Right, if we remove everything from the plugin except the TMS YXZ
>> >>> layers,
>> >>> we
>> >>> could also just have a better ergonomy for opening this kind of layers
>> >>> through
>> >>> GDAL, and have a predefined list of layers accessible on internet
>> (even
>> >>> auto-
>> >>> updatable by downloading the list).
>> >>> Vincent
>> >>> _______________________________________________
>> >>> Qgis-developer mailing list
>> >>> Qgis-developer at lists.osgeo.org
>> >>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140407/42023b6a/attachment-0001.html>
