[Qgis-developer] new plugin "Load TMS Layer"
Etienne Tourigny etourigny.dev at gmail.com
Mon Apr 7 19:24:34 PDT 2014
Matthieu,
Thanks for your input!
I will change the project CRS by default but make it optional.
Do you have a xml file for the TMS of the Global Forest Change, or any info
on what server it uses or at least the path?
While working on it I realized the power of the caching - I am taking
advantage of that and setting the proper cache directory.
cheers
Etienne
On Mon, Apr 7, 2014 at 11:00 PM, Mathieu Pellerin <nirvn.asia at gmail.com>wrote:
> Nice, few comments (based on my previous uses of the GDAL TMS mini-driver):
> - your plugin should make sure the loaded layer is assigned the proper
> projection (mostly pseudo-mercator); failing to do so will leave must users
> unable to understand why the TMS rendering fails
> - that would also switch OTF reprojection on when needed
> - consider adding TMS of the Global Forest Change (see
> http://www.earthenginepartners.appspot.com/science-2013-global-forest for
> data source, and
> https://www.flickr.com/photos/60284107@N00/11096344994/in/pool-qgis-screenshotsfor in-QGIS example)
> The GDAL TMS driver is in many ways a superior solution to OpenLayers; it
> works perfectly fine with the multi-thread rendering, can be exported via
> qgis composer, caches the tiles, etc.
> Math
> On Tue, Apr 8, 2014 at 4:45 AM, Etienne Tourigny <etourigny.dev at gmail.com>wrote:
>> I have put together a simple plugin to load a number of TMS layers using
>> the GDAL TMS mini-driver [1]. I see it as a simple alternative to the more
>> complete OpenLayers plugin.
>> Code is at github for now [2]. Any suggestions are welcome (including
>> plugin name). Also if you have any other working examples please let me
>> know.
>> Supported layers are OSM, Google, and other examples given in [1] (except
>> those that don't work).
>> Tested with QGIS 2.2 and master. Rendering of labels is not the best but
>> it seems better with master.
>> [1] http://www.gdal.org/frmt_wms.html
>> [2] https://github.com/etiennesky/loadtmslayer
>> cheers
>> Etienne
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140407/d933009b/attachment-0001.html>
