[Qgis-developer] Aliases of features attributes in Mapserver's WMS GetProjectSettings and GetFeatureInfo
Marco Hugentobler marco.hugentobler at sourcepole.ch
Tue Apr 8 00:26:19 PDT 2014
Hi Marcel
Sounds good to have both name and alias in GetProjectSettings and to use
name for FILTER.
 >Another question is, what should be used as attribute name in
GetFeatureInfo response, alias or name? Current mapserver returns prefer
aliases (if defined) in plain XML format, >but in GML format it always
returns names. In my opinion, names should be used in both formats and
aliases could be passed as additional info (if particular format allows
that), >or not used at all in GetFeatureInfo cause clients would be able
to perform mapping from names to aliases by info from GetProjectSettings.
I think it should behave similar to the info-tool in QGIS and give the
alias. Standard WMS clients can then display the text / html without
being aware there is a difference between name/alias. Specialised
clients (e.g. QGIS webclient, Lizmap, ...) can read alias / name from
project settings and use that for filter string (which is also
non-standard).
 >but in GML format it always returns names
 >And the last issue is that mapserver always returns all features
attributes in GetFeatureInfo response is GML format, even if they are
marked to be excluded in WMS server.
These are two bugs in the gml featureInfo code.
Pull requests are welcome. However, to avoid merging conflicts, it might
be good to wait for https://github.com/qgis/QGIS/pull/1296 .
Regards,
Marco
On 08.04.2014 08:05, Marcel Dancak wrote:
> Hi, I found some issues in Mapserver when using aliases for features
> attributes.
> GetProjectSetting response has features attributes of vector layer in
> this form
> <Attribute typeName="INTEGER" precision="0" length="0"
> editType="LineEdit" type="qlonglong" comment="" name="PK_UID"/>
> where "name" property contains either attribute's alias (if defined)
> or its name. So you are loosing attribute's name when using aliases,
> and that make it impossible to perform searching by this attribute
> with GetFeatureInfo request (with FILTER parameter). Separate "alias"
> property would be much better.
> prefer aliases (if defined) in plain XML format, but in GML format it
> always returns names. In my opinion, names should be used in both
> formats and aliases could be passed as additional info (if particular
> format allows that), or not used at all in GetFeatureInfo cause
> clients would be able to perform mapping from names to aliases by info
> I have all these issues fixed and I can create a pull requests, but
> first I want to discuss about it and maybe another solutions will came
> out.
> Marcel
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
