[Qgis-developer] Problems uploading plugin to repository
Tim Martin tjmgis at gmail.com
Thu Apr 10 07:38:19 PDT 2014
hi alessandro
I had read the info on this page
http://www.qgis.org/en/docs/pyqgis_developer_cookbook/plugins.html
There is an example of the directory structure, but I just hadn't zipped my
plugin folder. I had zipped my plugin files instead
So all sorted now
thanks
Tim
On 10 April 2014 15:34, Alessandro Pasotti <apasotti at gmail.com> wrote:
> 2014-04-10 14:32 GMT+02:00 Tim Martin <tjmgis at gmail.com>:
> Hi Werner
>> So simple! Yes that has fixed my problem
>> Many thanks for your help
>> Tim
> Tim,
> did you check if this information is in the manual?
> If it isn't, can you add it?
> Alessandro Pasotti
> w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140410/a959cfdb/attachment.html>
