[Qgis-developer] windows package creation
matteo
matteo.ghetta at gmail.com
Fri Apr 11 02:53:14 PDT 2014
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi all,
I keep on trying to create a package for windows with the
**creatensis** script.
Launching the script normally, the package is created and it works
nice (I tested it on a Virtualbox machine).
I saw that the creatensis has various options, and I have just a few
(simple) questions about the customization and the packaging itself:
- - how can I specify the version of QGIS I want to create? I cannot
understand how should I use the **-version** option.
- - if, for example, I want to include in the package some additional
plugins and a customization.ini file of the GUI, I have to add in a
**addons** folder (line 186 of creatensis script). But how should I
specify files I put in here? Just create the folder *addons* in the
parent directory of creatensis and put them in?
- - finally, given that I'm doing some attempts, every time I run
creatensis (because something didn't worked), it re-downloads all the
files from the server. Is there an option that allows to not download
all the packages and using the downloaded ones in order to speed up
the entire process?
Thanks for the patience.
Cheers
Matteo
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.12 (GNU/Linux)
Comment: Using GnuPG with Icedove - http://www.enigmail.net/
iQEcBAEBAgAGBQJTR7uIAAoJEBy7UYf0gaEOTxIIALH2jhIFzkR6NB03/h0rJ1N6
DaTejG/v6uX7KSzyjSgZHE5QW9f5hiZi5KXRf3FlfZ6wLtP+ywNJkzMmQCEvL5RX
JVWLlrhCzl20j8sW37k53fcDEYT1U1eGeeevdRPLC6TGKUR3HAkDgiDjnR4JEf0M
YIpG5ni9s3PETHjk2JWMLWBQA75x8cBDSpghxoA9ch0e5bszbYKtBINvX7v17xze
HPe6Sa7LpJfJnzbf9jeCKJxJAq8ZW4Urz0TuyX0iKCG21p72IqJ5lfIlnUpQPrus
VVFKPGSmvujpAsgVQN7pCyEALvONyZwU1bjWnjqjEDWZ4K64wj6uNvnvWMzHlZk=
=40M/
-----END PGP SIGNATURE-----
