[Qgis-developer] [Qgis-user] Installing QGIS Server on RedHat EL 6.5
Olivier Dalang
olivier.dalang at gmail.com
Tue Apr 22 05:53:24 PDT 2014
Hi !
Still about this : do you plan to continue maintaining packages for
qgis-mapserver for RHEL ?
If so, do you have an ETA for 2.2 (or 2.4) ?
If not, I guess I'll either have to switch distro or learn how to compile
the mapserver...
Thanks !
Olivier
2014-03-22 0:00 GMT+01:00 Matthias Kuhn <matthias.kuhn at gmx.ch>:
> 2.2 is not that easy because it requires qt>=4.7 and rhel comes with
> qt-4.6.2.
> So without reverting some commits or compiling new qt packages (which
> likely have additional dependencies) this won't be an option.
> Instead there are now new packages (qgis-2.0.1-2) available which are
> based on the latest release-2_0 patches (f802808)
> I tested here in a docker container and was able to install (didn't do
> any more tests actually):
> docker pull centos
> docker run -i -t centos /bin/bash
> rpm -Uvh
> http://mirror.karneval.cz/pub/linux/fedora/epel/6/x86_64/epel-release-6-8.noarch.rpm
> rpm -Uvh http://elgis.argeo.org/repos/6/elgis-release-6-6_0.noarch.rpm
> wget fedora.vitu.ch/EL/qgis.repo -P /etc/yum.repos.d/
> rpm --import http://fedora.vitu.ch/Fedora/RPM-GPG-Key-vitu
> yum update
> yum install qgis
> Hope this helps
> Matthias
> On Fre 21 Mär 2014 18:19:38 CET, Olivier Dalang wrote:
> > Great !! Many thanks :)
> > Do you have an estimate of when you could be done ? (hours / days /
> > weeks ?)
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140422/d4d74df9/attachment-0001.html>
