[Qgis-developer] [Qgis-user] Trusty 14.04 install from QGIS.org
Zoltan Szecsei zoltans at geograph.co.za
Tue Apr 22 10:23:06 PDT 2014
Hi DevList,
I've moved this over from 'user' to 'dev'.
Is there an upcoming fix to get python-qgis working with the
sip-api-11.0 that comes with Ubuntu 14.04 64 bit?
Thanks,
Zoltan
On 2014/04/22 00:58, Randal Hale wrote:
> Just for fun I upgraded a test install of ubuntu 12.04 to 14.04.
> Master Debian-nightly installs nicely.
> Stable release for trusty complains:
> /rjhale at gis2:/etc/apt/sources.list.d$ sudo apt-get install qgis
> python-qgis//
> //Reading package lists... Done//
> //Building dependency tree //
> //Reading state information... Done//
> //Some packages could not be installed. This may mean that you have//
> //requested an impossible situation or if you are using the unstable//
> //distribution that some required packages have not yet been created//
> //or been moved out of Incoming.//
> //The following information may help to resolve the situation://
> //The following packages have unmet dependencies://
> // python-qgis : Depends: python-qgis-common (= 2.2.0-1+trusty1) but
> it is not going to be installed//
> //               Depends: sip-api-10.1 but it is not installable//
> // qgis : Depends: libqgis2.2.0 but it is not going to be installed//
> //        Depends: libspatialite3 (>= 2.4.0~rc2) but it is not
> installable//
> //        Depends: qgis-providers (= 2.2.0-1+trusty1) but it is not
> //        Recommends: qgis-plugin-grass but it is not going to be
> installed//
> //        Recommends: qgis-plugin-globe but it is not going to be
> installed//
> //E: Unable to correct problems, you have held broken packages./
> Just an FYI -
> Randy
> Randal Hale, GISP
> North River Geographic Systems, Inc
> http://www.northrivergeographic.com
> 423.653.3611rjhale at northrivergeographic.com
> twitter:rjhale
> http://about.me/rjhale
> Qgis-user mailing list
Zoltan Szecsei PrGISc [PGP0031]
Geograph (Pty) Ltd.
GIS and Photogrammetric Services
P.O. Box 7, Muizenberg 7950, South Africa.
Mobile: +27-83-6004028
Fax:    +27-86-6115323     www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140422/0ad0eee6/attachment.html>
