[Qgis-developer] QGIS master crashes on zoom in - zoom out
Pedro Venâncio
pedrongvenancio at yahoo.com
Fri Apr 25 12:38:19 PDT 2014
I've compiled and installed yesterday QGIS 2.3 master, on Xubuntu 12.04, but it is continually crashing with a segmentation fault (core dumped). I just load a layer (raster / shape / postgis) and do some zoom in / zoom out. I've tried with the option to render with all processor cores active / deactivated, but it happens exactly the same. I've also uninstalled the CADInput plugin, because I read somewhere that it could give problems, but not resolved.
On the console::
$ qgis
Warning: loading of qt translation failed [/usr/share/qt4/translations/qt_en_US]
Warning: QGraphicsScene::addItem: item has already been added to this scene
no need
false; DefaultProxy; ; ; ; *********;
breaking!
breaking!
breaking!
breaking!
breaking!
breaking!
breaking!
breaking!
breaking!
breaking!
breaking!
breaking!
breaking!
breaking!
breaking!
breaking!
breaking!
Segmentation fault (core dumped)
The faster I zoom in / zoom out, more "breaking!" appears, until the Segmentation fault... See here:
https://dl.dropboxusercontent.com/u/5772257/qgis/crash.ogv
https://dl.dropboxusercontent.com/u/5772257/qgis/crash_nightly.ogv
In the first attempt I was using the ubuntugis-stable repository, with gdal 1.9.x. However, I updated all packages with ubuntugis-unstable, and went back to compile, but the same thing happens.
In a last attempt, I tried the nightly builds, also without success.
I've uninstalled everything that was associated with qgis, grass, gdal; erased folders .qgis2 and .config/QGIS, but still crashes...
Error reports always refer to something related to QgsMapRenderer: SIGSEGV in QgsMapRenderer::extent() / QgsMapRenderer::updateScale() / QgsMapRenderer::adjustExtentToSize():
https://dl.dropboxusercontent.com/u/5772257/qgis/relatorio_erro_qgis.png
https://dl.dropboxusercontent.com/u/5772257/qgis/relatorio_erro_qgis_2.png
https://dl.dropboxusercontent.com/u/5772257/qgis/relatorio_erro_qgis_3.png
Does anyone have any idea about what may be the cause?
Thank you very much!
Best regards,
Pedro
