[Qgis-developer] [Qgis-user] Centroid of polygon
Andreas Neumann a.neumann at carto.net
Tue Aug 5 02:58:10 PDT 2014
For me it is very strange that
x(centroid($geometry))
y(centroid($geometry))
does not work in the QGIS expressions.
There is a $x and $y - but this does only work directly on a current
feature if it is a point feature.
The workaround with xmin/ymin
xmin(centroid($geometry))
ymin(centroid($geometry))
works, but seems cumbersome.
Could you open a ticket please?
Andreas
Am 04.08.2014 17:22, schrieb Goyo:
> This works in master:
> Goyo
> 2014-08-04 18:28 GMT+02:00 Jonathan Moules <jonathanmoules at warwickshire.gov.uk>:
>> Hi list,
>> Quick question, how do you use the Field Calculator to get the centroid as
>> an attribute? I'm aware of this question answer:
>> http://gis.stackexchange.com/questions/11705/using-field-calculator-in-qgis-to-update-columns-with-centroid-coordinates
>> - but want to do it using just the field calculator.
>> I see under "Geometry" that there's a "centroid" function, but can't figure
>> out how to use it for this purpose.
>> Suggestions welcome.
>> Thanks,
>> Jonathan
>> This transmission is intended for the named addressee(s) only and may
>> contain confidential, sensitive or personal information and should be
>> handled accordingly. Unless you are the named addressee (or authorised to
>> receive it for the addressee) you may not copy or use it, or disclose it to
>> anyone else. If you have received this transmission in error please notify
>> the sender immediately. All email traffic sent to or from us, including
>> without limitation all GCSX traffic, may be subject to recording and/or
>> monitoring in accordance with relevant legislation.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
