[Qgis-developer] Compile SIP windows 7
Larry Shaffer larrys at dakotacarto.com
Sun Aug 10 08:52:42 PDT 2014
This mailing list for QGIS-related development. Questions about issues of
compiling other software should be directed to their appropriate support
channels, like the PyQt mailing list [0].
If you are looking to set up a development environment on Windows for QGIS,
consider using the OSGeo4W installer and building QGIS upon its supporting
libraries, instead of compiling all the dependencies yourself. See the
INSTALL document for info on this [1].
[0] http://www.riverbankcomputing.co.uk/support/lists
[1] https://github.com/qgis/QGIS/blob/master/INSTALL#L547
Regards,
Larry Shaffer
Dakota Cartography
Black Hills, South Dakota
On Sun, Aug 10, 2014 at 6:10 AM, otmane yazidi alaoui <
yazidiotmane at gmail.com> wrote:
> C:\Users\otmane\Downloads\sip-4.11.2>c:\python27\python configure.py
> --platform
> win32-g++
> This is SIP 4.11.2 for Python 2.7.8 on win32.
> The SIP code generator will be installed in c:\python27.
> The SIP module will be installed in c:\python27\Lib\site-packages.
> The SIP header file will be installed in c:\python27\include.
> The default directory to install .sip files in is c:\python27\sip.
> The platform/compiler configuration is win32-g++.
> Creating sipconfig.py...
> Creating top level Makefile...
> Creating sip code generator Makefile...
> Creating sip module Makefile...
> C:\Users\otmane\Downloads\sip-4.11.2>make
> mingw32-make[1]: Entering directory
> `C:/Users/otmane/Downloads/sip-4.11.2/sipgen
> makefile:29: warning: overriding commands for target `.c.o'
> makefile:26: warning: ignoring old commands for target `.c.o'
> mingw32-make[1]: Nothing to be done for `all'.
> mingw32-make[1]: Leaving directory
> `C:/Users/otmane/Downloads/sip-4.11.2/sipgen'
> `C:/Users/otmane/Downloads/sip-4.11.2/siplib
> `C:/Users/otmane/Downloads/sip-4.11.2/siplib'
> --platform
> win32-g++
> C:\Users\otmane\Downloads\sip-4.11.2>make install
> "C:/Program Files/Git/bin/sh.exe": -c: line 1: syntax error: unexpected
> end of f
> ile
> mingw32-make[1]: *** [install] Error 258
> mingw32-make: *** [install] Error 2
>        YAZIDI ALAOUI OTMANE
>            Ingénieur d'état en Géomatique
>                    Tel:+212652538743
>                    @ :yazidiotmane at gmail.com
> http://www.doyoubuzz.com/otmane-yazidi-alaoui
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140810/b7ca58bb/attachment-0001.html>
