[Qgis-developer] After upgrade all fields are editable in QGIS project file
Markus Innerebner
mailinglist.innerebner at gmail.com
Mon Aug 11 00:30:59 PDT 2014
Hi Matthias,
> Hi Markus,
> Are you able to switch them back to non-editable? Somebody reported
> issues that he is not able to turn editing off [1].
Turning the editing off is possible on fields. So this issue I can not
confirm.
> If you open your old files with the current development version, does
> the same happen? IIRC jef made some changes that could have fixed this.
In that case, QGIS is upgrading the project to the Chugiak version and
the problem I specified in the previous mail occurs.
kind regards
Markus
